Hi.
I have problem with open GL in 3d window, it's black! 😕
The 3d window in archicad goes black when i press F5. I can only see the objects when i move and rotate the screen. I can't model in 3d wondow. I've tried to change some open Gl settings but nothing happens.
Please help..
Thanks.
One of the forum moderators. Versions 6.5 to 27 Dell XPS- i7-6700 @ 3.4Ghz, 16GB ram, GeForce GTX 960 (2GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
I think that updating the graphic card drivers would be much more beneficial than a quicktime update as it's the graphic card and the drivers that generate your OpenGL view.
Does the same thing happen with small models or on different projects?
thanks for the reply..
my drivers are already up to date. there are no latest updates for my graphic card. 3d window is black what ever project i open or even when i create new project.. i do not have problems with any other opengl application..
i have reinstalled drivers, install them again again, removed them then put older ones i got on cd with graphic card...etc... i also find some fix for new drivers, tried them out, still nothing.. i also updated opengl..same thing happens.. i really have no ides what else to try.. i've tried also the older version of archicad, and same thing happens! maybe is there some fix for open gl or something..?
