2024-03-04
05:35 PM
2024-03-05
01:07 AM
Hello ArchiCAD Community!
I'm interested in adding more Physical Properties to ArchiCAD materials so we can show things like R/in or cost per sq ft. Is that possible? I opened the .xml file where the Physical Properties are stored, but when I tried to save my edits, it didn't let me.
Our office runs ArchiCAD 24 on macOS 12.7.2 (Monterey)
Thank you!
Justin
Solved! Go to Solution.
2024-03-05 01:10 AM - edited 2024-03-05 01:11 AM
You will not be able to use Expressions when working with Properties assigned to Building Material classifications since Properties are element-level values, while Building Materials are relevant to sub-elements (skins of Composite Structures and components of Complex Profile elements).
2024-03-04 06:29 PM
AFAIK -- Physical properties of building Materials are hard coded as part of the Building material element structural. You would have to modify the API structure , but i am not sure that that would carry through to the UI --- probably not. You can, however, easily add a custom property to any Building Material through the Property Manager by just setting the proper material classification (availability) corresponding to the the one used on the applicable Building Material.
2024-03-04
06:37 PM
2024-03-05
01:08 AM
Thank you for the reply! Yes, I figured out how to add the properties to the materials, but I'm not being able to figure out how to add expressions to them.
For example, I was able to add the R/in property as a number to my materials, but I'm not able to reference the thickness parameter of each individual material in a composite to create an expression that would show me the total R-value for that composite. It doesn't seem like you can reference components in expressions.
2024-03-05 05:38 AM
AFAIK --- One way to calculate the sum of wall component resistance would be to use a Python script and the function:
