Sustainable design
About EcoDesigner, Energy Evaluation, Life Cycle Assessment, etc.
Create schedule for GWP of objects
MarilinaA
I am trying to create a schedule in archicad where we can show the GWP and CO2 content of each piece of furniture. Furniture is either an object from Archicad library, or furniture we have imported from suppliers. I have also tried the LCA Plug in, but this only calculates building material, and not an object.
I appreciate any advice!
Operating system used: Windows 27.0.0.6000
1 REPLY 1
Jeff Thompson
I think the following artical might help you out.  You can create custom classifications and properties in Archicad that can be scheduled and can be called out within objects properties.  The CO2 properties can be turned on and represented in an oject from the Combustion catagory. The GWP would likely need to be created as a custom catagory.
https://help.graphisoft.com/ac/25/int/_ac25_help/045_PropertiesClassifications/045_PropertiesClassif....
Let me know if you need further help.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
Setup info provided by author
