JohnJay
Daylight Analysis in Archicad?
Is it possible to do Daylight Analysis natively in Archicad?
I have Octane Render too if that helps?
Surely all the data is there and just needs to be extracted?
AC27 | i7990x | RTX4070 | W10
3 Replies 3
PB
Very pertinent question - sad that there appears to be no means to extract a Daylight Analysis directly from the model in Archicad
AC29. Twinmotion.
16" M1 Max MacBook Pro 32GB, Apple Studio Display, MacOS 26 Tahoe
PB
One solution is proposed by Graphisoft (additional subscription)…
https://www.graphisoft.com/partner-solutions/lightstanza/
AC29. Twinmotion.
Patrick M
Ace
you can set date/time, and if your project location and north are accurate, you can get accurate sun studies from archicad; but in terms of getting area/volume/etc. calcs, I don't thin theres a tool for that.
I have used archicad to produce ResCheck/ComCheck, just extracting areas/glazing/etc.; and I've used it to present solstice studies on relevant elevations. But nothing that is going to tabulate actual spread sheets.
