2009-07-22
08:59 PM
2023-05-11
10:24 AM
Noemi Balogh
2009-07-22 11:47 PM
2009-07-23 03:23 AM
2009-07-23 03:32 PM
2009-07-23 05:26 PM
2009-07-23 10:20 PM
2011-04-08 06:49 PM
2011-04-14 11:39 AM
Symm wrote:I am having the same problem like the author of the topic - simply I can not install the Eco designer.
This is usually a renaming issue. If you have renamed the ArchiCAD application, to say "ArchiCAD 12" to differentiate between versions for example, it will not recognize it. The name of the application itself must be the default "ArchiCAD" for the EcoDesigner installer to recognize it. You can then switch the name back after if you like.
2011-04-14 06:01 PM
2011-04-15 10:09 AM
