2014-07-24
03:34 PM
2023-05-11
10:44 AM
Noemi Balogh
2014-07-28 03:29 PM
aleksey51 wrote:GSHQ Technical Support will investigate it.
Hello
When I use any type of shading device in my project, simulation does not work!
I get the message "Offset values in shading schedule invalidates shading, fin, constraints ((90 >= eth + offset >= 0) > (90 >= thorn + offset >= 0))."
Problem can be solved if I select "Solar Analysis off" for some openings. But it will affect the results of a simulation
What should I do?
2014-07-30 11:35 AM
2014-08-02 02:54 PM
