Sustainable design
About EcoDesigner, Energy Evaluation, Life Cycle Assessment, etc.
Importing/ exporting Ecodesigner materials in AC 16
Hi everyone, I'm testing my brand new Archicad 16 and was wondering: how can I export the product catalogue of my Ecodesigner materials?
I was able to export it as .xml file from Archicad15+ED, but I could not find a way to do the same in version #16.
Thanks!
Enrico
4 REPLIES 4
Do you want to use the XML Material catalog in AC16?
I think you can just add it manually to the MaterialCatalog.xml file in the EnergyEvaluation folder.
On my computer it is at:
C:\Program Files\Graphisoft\ArchiCAD 16 INT\Add-Ons\EnergyEvaluation\INT
Excellent! That's exactly what I needed.
Any chance I can add a custom material library, like I can add custom object libraries and databases?
Thanks again!
I am not absolutely certain, but I suppose that this is the XML file ArchiCAD reads when you click the Material Catalog button in the Fill Types Dialog. So I think there must be one such file.
What I would do is I would create these Material Groups with easily identifiable names. Then I would place them either at the beginning or the end of this XML files. As I see ArchiCAD reads the file contents in sequence so if you put them at the beginning they will be in the beginning in the Material Catalog Dialog.
Ok, I'll try. Thanks again!
