‎2014-08-28 03:58 PM
‎2014-08-28 04:01 PM
‎2014-08-28 11:30 PM
Jesikuh123 wrote:we opened up ports 1228 and 8081 on our router and offsite consultants have been able to sign-in to our projects... sounds like you might need to open up port 18008 on your router too? i'm not too much of an expert in all things networking but it seemed to work for us....
When i go to check connections it says that I am connected to the bim server with green check marks, so i think that implies that it is OK.
But under that there is a v18 - Module that shows the same address as my bim server but the port number is different, it is not :1228 which is what my bim server is, it is :18008!
‎2014-08-29 03:30 PM
‎2014-08-30 12:22 AM
‎2014-08-30 12:23 AM
