Archicad 18 Bim Server "Address"
This is probably dumb - but where do I find what my BIM server Address is so I can enter that into ArchiCad so I can share my project in Teamwork?
37 Replies 37
thanks ejrolon for ur answer...
i already follow step by step just like ur link reference
but it still not working....
this is the third time i reinstall my BIM S....
please check out attchmnt pict..
i cannot change the module name..is that the problem???
after installation proccess finish, the first screen shoot that i send b4, appear in browser,
its never refer me into "create a new admin BIM S"
Thanks
Eduardo Rolon
You don't need to change the module name.
It is supposed to show up again. If I remember correctly:
- Press start
- Then create a new administrative user
- At one point you will need to create a graphisoft account if you don't have one in order to register your BimServer
- then you should be done.
You will need to read the manual to see if those steps are correct. Page 30 of the "AC18 Getting Started Manual"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
thanks for ur help n time Ejrolon...but i still found this is not working...
i'll attch more screenshoot from installation proccess...
