Lee KiSeong
Archicad 29 is unusable due to Teamwork errors. Please review a measure to provide a partial refund
Archicad 29 is unusable due to Teamwork errors. Please review a measure to provide a partial refund of the Archicad 29 subscription fee.
Hello.
This is the first time in 14 years I have had such a terrible experience.
The client computers are Macs. The server is Windows 11.
The time servers are all identical, set to time.apple.com. (I even attempted to unify the time on the Windows server using the UTC method, but it was of no use.)
The error shown in the image below appears 3 to 4 times a day, causing about 30 minutes to an hour of work to vanish each time. I am suffering significant financial loss.
I converted from a perpetual license to a subscription and prepaid for 3 years.
The exact same issue occurs in SaaS as well. Only in version 29!
Graphisoft has completely failed with version 29.
What is even more despairing is that I have seen many reports of similar issues to mine in the community.
Yet, Graphisoft has absolutely no idea what the cause is.
I received a response telling me to clear the cache files and test again.
If the cache files are the problem, then why does version 28 work perfectly fine without issues?
Please take a look at what I have gone through over the past 2-3 days.
AC 28 | M3 MAX | MAC OS 15
BIMcloud | Xeon Gold 6142 x 2 | WIN 11 PRO for Workstation
44 Replies 44
Lee KiSeong
Once again, I have never encountered this error in 14 years. Furthermore, my current hardware and network setup has remained unchanged for three years. I experienced absolutely no issues throughout versions 26, 27, and 28. Even now, there are no issues whatsoever with version 28.
If my network were the problem, version 28 should also be failing. The issue occurs exclusively in version 29. Even if, by some chance, the issue lies in the migration process from version 28 to 29, that is still Graphisoft's fault for not handling the migration correctly.
Our office setup is very simple, with all computers connected via a single HP Gigabit switch. What specific setting could possibly be causing this? We are using the same build number and are connected to the same switch hub.
We do have a mix of Intel and Apple Silicon machines, but if that were the cause, it should also trigger issues in version 28. Version 28 works perfectly fine.
We have now abandoned version 29 and are using version 28. We are very happy. As long as I don't think about the money I threw away upgrading to version 29.
I performed only one action on our perfectly working BIMcloud: upgrading to version 29. And that action is what caused this incident.
torben_wadlinger
Sorry, but this issue is discussed here up and down: https://community.graphisoft.com/t5/Teamwork-BIMcloud/BIMcloud-warnings-are-getting-out-of-control/m...
The common conclusion is that the problem is 100% on Graphisoft. And the problem is not just with AC29 but exists since years. So the call for a refund is totally legit.
Lee KiSeong
The demand for a refund was just me venting. I know they won't grant it anyway. From today on, I'm just going to forget about this for a year. I'll just use version 28 until version 30 is released. After all, I already prepaid for a 3-year subscription!
schagemann
Out of interest how big are your Archicad project files on average and what is the external reference / hotlink setup?
VKTRS | macinteract
Design Technology Managers - all on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
Lee KiSeong
Our average project size is between 600MB and 4GB. We typically use about 3 to 5 Xrefs, and we rarely use Hotlinks.
Lee KiSeong
Are you the developer of Smart Tree? I visited the link in your profile, and it looks like a great object. I think I will purchase it in the near future.
Is this 600MB to 4GB the size of your PLN files? A 1 GB PLN files is considered large, and above 2 GB it can be critical, and you could be running into the limitations of hardware/software.
Lee Hankins
Do you have any external files such as PDF’s or JPEG’s loaded in to the file either in the model or on the layouts? We’ve found this can cause performance issues especially with Teamwork when the Teamwork file is on the BIMcloud server and the imported PDFs or JPEG’s are stored locally or a network server. If this is the case, use the Drawing Manager palette to break the links. That may help.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Lee KiSeong
Hello, thank you for your input. However, I have reverted the exact same project file that had issues in v29 back to version 28, and I have been working without a single issue for the past 3 days. I’ve got my happy daily routine back—as long as I don't think about the money wasted on the v29 upgrade.
And regardless of whether it’s 600MB or 4GB, shouldn't it work properly? For the past 5 years, I have exclusively handled projects larger than 2GB and never had any problems—until I met Archicad 29.
Lee KiSeong
Thank you. I would like to inform you that issues occurred in both of the two projects where I migrated files that were working perfectly in version 28 to version 29. Now that I have reverted all those projects back to version 28, I am working without any issues whatsoever. Isn't ensuring that older project files work seamlessly in version 29 a promise between Graphisoft and its consumers?
Yes, PDFs and JPGs are loaded. That is a native function of Archicad. It is supposed to work properly; the mere presence of these files should not cause issues.
I repeat once again: there are absolutely no problems when using version 28 in the exact same environment.
