2014-07-19 10:53 PM
2014-07-26 08:10 PM
2014-07-26 09:14 PM
2014-07-28 01:33 PM
another Moderator
2014-07-29 01:17 AM
ejrolon wrote:Hi,
If you had an error on install then you need to uninstall and try again. Check that you have the correct permissions on the folder that BimS is installing to.
If you already installed without problems then check that you have a static IP for the computer running Bimserver? If not then you need to assign one because without it the other computers cannot connect to it.
2014-07-29 01:21 AM
another Moderator
2014-07-29 01:45 AM
ejrolon wrote:Hi Ejrolon,
Then my recommendation is to get in touch with your reseller. I have installed only 2 Bimservers and both went without problems so I have no idea what is going wrong with yours but if it was widespread you would not be alone with the problem. I think there is a step that you are missing but I have no idea what it is or how to find it.
2014-07-29 04:56 AM
Mjules wrote:Since your profile lists your license as a full, professional version (not EDU)... why torture yourself for weeks, when you have free technical support available? As I said earlier...and Eduardo has also... contact your reseller for tech support and move forward.
I have tried again, again and again since a couple of weeks !
2014-07-31 04:25 AM
Karl wrote:Graphisoft is in charge of this technical problem now !Mjules wrote:Since your profile lists your license as a full, professional version (not EDU)... why torture yourself for weeks, when you have free technical support available? As I said earlier...and Eduardo has also... contact your reseller for tech support and move forward.
I have tried again, again and again since a couple of weeks !🙂
