Eduardo Rolon
Best procedure to restart the BimServer 18
How do you restart TW when the bimserver crashes and the web interface says that it is not available?
I just open a TW file found that I was offline, checked that the static IP address on the server had not changed and since it hadn't and I was still offline then went to the second step of clicking on "Reconfigure v18 module" since it is the only place I have found a "restart" button and clicked.
The result is everybody was kicked out of the Bimserver!!!
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
6 Replies 6
Martin Jules
Mentor
When I try to do so, a message error occurred. Please see the attached file.
Martin Luther Jules
AC 10-29 (Full)
Asus | 64 GB RAM | Windows 11
Marton Kiss
Eduardo,
please find here an article shwoing how you can restart BIM Server 18 manually or check if its services are running: http://helpcenter.graphisoft.com/?p=41958
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
Eduardo Rolon
Thanks Marton
Will double clicking the files work?
Martin (Mjules) though your question has nothing to do with mine and I am just guessing, if you are installing on a Mac please check that your permissions are correct on the folder that you are installing and that you are running as administrator before installing BimServer. If you are installing on Windows I cannot be of help.
For future reference, it is not a good practice to hijack threads since it makes finding answers difficult.
AC29 US/INT -> AC08
Marton Kiss
ejrolon wrote:
Thanks Marton
No, on Mac you will need to use the terminal commands, so first of all open terminal.
For a complete restart first stop the server:
- sudo launchctl unload /Library/LaunchDaemons/com.graphisoft.PortalServerService-v18.0.plist
- sudo launchctl unload /Library/LaunchDaemons/com.graphisoft.TeamworkApplicationServerMonitor-v18.0.plist
then start it again:
- sudo launchctl load /Library/LaunchDaemons/com.graphisoft.PortalServerService-v18.0.plist
- sudo launchctl load /Library/LaunchDaemons/com.graphisoft.TeamworkApplicationServerMonitor-v18.0.plist
Marton Kiss
GRAPHISOFT
Eduardo Rolon
Marton,
Had to restart the server today since it crashed. The terminal procedure works but it is a pain to do. This needs to be rethought.
AC29 US/INT -> AC08
Marton Kiss
We absolutely agree and are working on a much easier way to start-restart-stop the server.
Marton Kiss
GRAPHISOFT
