2014-07-24 03:01 AM
2014-07-28 05:00 AM
2014-07-28 08:07 AM
ejrolon wrote:Eduardo,
How do you restart TW when the bimserver crashes and the web interface says that it is not available?
I just open a TW file found that I was offline, checked that the static IP address on the server had not changed and since it hadn't and I was still offline then went to the second step of clicking on "Reconfigure v18 module" since it is the only place I have found a "restart" button and clicked.
The result is everybody was kicked out of the Bimserver!!!
2014-07-28 01:31 PM
2014-07-28 01:47 PM
ejrolon wrote:No, on Mac you will need to use the terminal commands, so first of all open terminal.
Thanks Marton
Will double clicking the files work?
2014-07-29 04:26 PM
2014-07-29 04:37 PM
ejrolon wrote:We absolutely agree and are working on a much easier way to start-restart-stop the server.
Had to restart the server today since it crashed. The terminal procedure works but it is a pain to do. This needs to be rethought.
