‎2010-09-01 05:02 PM
‎2010-10-13 04:33 AM
vfrontiers wrote:You do need to keep the attachments on the same disc. Can you move some of the other shtuff now on the server onto the external drive?
BTW, I am asking because my server machine is running out of HD Space on it's internal drive, but there's room a plenty on an attached external drive.
vfrontiers wrote:Manual update. It's actually a reload of the folder or lcf.
Also... what happens when my OFFICE LIBRARY, set up as a BIM Library has additions and subtractions? Does TW2 sync it? Or is there a manual sync required?
‎2010-10-13 01:57 PM
‎2010-10-13 04:37 PM
‎2010-10-13 04:53 PM
I am still concerned that working NON TEAMWORK projects and updating library parts will not flow thru to the Bim Server Library... Do I need to relegate ALL projects to the BIM SERVER?We haven't had any issues using BIM Server Libraries on non-teamwork projects.
Does it help if I create .lcf of my library?I have tried to do this before, but didn't seem to make any difference.
‎2010-10-13 06:05 PM
‎2010-10-13 06:19 PM
Erika wrote:Sooooo.... if I just loaded my VF_OFFICE_Lib onto the server... it ends up bottled up in a YADAYADA.db file in the attachments folder, yes?
I put all libraries on the BIM server and use the same ones for solo projects so there is no maintenance duplication effort.
For set libraries like the Archicad ones or smart parts I use lcf. This forces all users to create new library parts rather than risk changing parts that are already in use.
New library parts can be maintained in folders and then only those folder need to be reloaded onto the BIMserver.
HTH
‎2010-10-13 08:43 PM
‎2010-10-15 04:04 PM
‎2010-10-18 10:26 PM
‎2010-10-19 08:35 AM
