‎2009-11-20 08:30 PM
‎2010-03-30 04:59 PM
laszlonagy wrote:That's what I'm saying.
So you are saying that the library is loaded but the elements within the library are not listed in the Object Settings Dialog?
‎2010-03-30 05:21 PM
‎2010-03-30 05:34 PM
laszlonagy wrote:We can't.
Go to the Library Manager Dialog and Add the BIM Server Library to the Project. Click the right-pointing arrow button to the right of the Add button at the top, choose Use BIM Server Library.
‎2010-03-30 05:36 PM
‎2010-03-30 05:48 PM
‎2010-03-30 05:56 PM
‎2010-03-31 10:11 AM
laszlonagy wrote:Thank you so much! This worked. We had not realized the difference in abilities between 'architetto' and 'architetto capo'. Thanks for all your help.
I think you Teamwork Role does not allow you to Manager Libraries.
You need to go to the BIM Server Manager and make sure that you have a Role that has the "Libraries Add/Modify" enabled. Otherwise the "Use BIM Server Libraries" option does not even appear in the Library Manager Dialog.
You can modify either the default Role you are assigned. Or you can modify your Role only for this Project.
In either case I think you will need to Leave the Project and then Join again before the changes can take effect.
‎2010-03-31 12:40 PM
