I have a problem that I have not yet seen posted...I migrated a file from AC12 thru creating a .pla file of the original teamwork file (I have also tried via simply sharing the .plp after opening in AC13, with no luck either).  Once I open the file and share it, I cannot figure out how to gain access to the default AC13 Library.
I have uploaded the library thru the BIM Library Manager dialog box to the BIM Server.  Here, I also see my extracted .pla file's library already loaded.  When I open the Library Manager dialog box, all I see is my .pla extracted library, but not eh default AC13 Library.  I have tried reloading, refreshing, removing and replacing the default library with no luck.
In testing and working out issues, I have set up the BIM Server on an unused machine on our network.  It is running 10.5.8, but no server os.  I have admin access.  Everything at this point seems to be fine, but I can't seem to take advantage of the default library.
Any thoughts?  Thanks in advance...
	MacBook Pro Apple M4 Max 128GB ram
OS X 13.6.7
AC28 - AC6.5
