BIM Server Library issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2009-11-20 08:30 PM
I have uploaded the library thru the BIM Library Manager dialog box to the BIM Server. Here, I also see my extracted .pla file's library already loaded. When I open the Library Manager dialog box, all I see is my .pla extracted library, but not eh default AC13 Library. I have tried reloading, refreshing, removing and replacing the default library with no luck.
In testing and working out issues, I have set up the BIM Server on an unused machine on our network. It is running 10.5.8, but no server os. I have admin access. Everything at this point seems to be fine, but I can't seem to take advantage of the default library.
Any thoughts? Thanks in advance...
OS X 13.6.7
AC28 - AC6.5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-11-20 08:33 PM
OS X 13.6.7
AC28 - AC6.5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-11-21 12:40 AM
HTH,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-11-21 12:43 AM
thank you though Karl...
OS X 13.6.7
AC28 - AC6.5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2010-03-26 05:02 PM
We had a project that we were working on from two different computers, one AC13 one AC12... sharing the file over our network. We upgraded the AC12 to 13 and decided to give teamwork a try. Uploaded the server and all appropriate libraries. But we have missing objects everywhere, and no ability to add new objects. In the BIM library manager window, our libraries have been uploaded. In the Library Manager for the file, they are not listed under BIM Libraries, nor can we add them anymore. Whereas you used to be able to 'chose' a library, it now asks us to 'open' and 'open' and 'open' until we get all the way down to specific elements.
going crazy here. HELP!
designer and sustainability consultant
Emu Architects
www.emuarchitects.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2010-03-29 02:24 PM
If you click it, you go to the Manage BIM Server Libraries Dialog, where you can login to the BIM Server and it will list the available libraries.
You need to select the Library in the list that you wish to add to your project and click the Add button. That will take you back to the Library manager Dialog and the library you just added will be listed under BIM Server Libraries. Then you need to Reload Libraries.
Is this what you are doing?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2010-03-30 12:17 PM
That is exactly what we did. Our libraries are listed correctly under the BIM Server Libraries in the Library Manager Dialog. We reloaded the libraries.
Then, when we want to create an object, in the Object Settings Dialog, where you should be able to search through the libraries - you cannot. They are not listed.
Any ideas?
thanks, Mariana
Emu Architects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2010-03-30 12:46 PM
So you are saying that the library is loaded but the elements within the library are not listed in the Object Settings Dialog?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2010-03-30 04:51 PM
here's the Library Manager Window
Emu Architects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2010-03-30 04:57 PM
Emu Architects
