Teamwork & BIMcloud
BIMCloud message
dhnguyen
Recently we upgraded to ArchiCAD 24. A new BIM Server is created and I am able to log in just fine from a browser.
However, I'm getting this message when I try to join a Team Work project, what is the problem and how can we fix it?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
insideru
If you use BIMCloud Basic, you need to select the AC version you want to work with.
In your browser, go to Servers - then select the server, then to the right select the version and hit save - see attached photo.
ARCHICAD 28 INT
macOS Sequoia
insideru
ARCHICAD 28 INT
macOS Sequoia
dhnguyen
Thank you!
DNguyen
ArchiCAD 18- 25
