2023-05-14 09:41 PM
Hi!
I just got an approval to use BIMcloud for our group project, i.e. Team licence. Unfortunately I use Archicad 25, while other members in the group have 26. Can we still work on the project, by using a library of Archicad 25, not 26?
I cannot update to a newer version, because my laptop is too old.
Thanks
2023-05-14 11:08 PM
That's too bad. A quick search here will show that everyone must be on the same version of Archicad to share a project. Your only option is for everyone else to use 25 for this group project.
2023-05-15 11:49 AM
Yes, and all of you need to have the same version and build also, for example, v26.5002, version 26, build 5002
2023-05-16 11:29 AM - edited 2023-05-16 09:11 PM
Hi Diora,
It is not possible to work in teamwork using different versions. Also, as far as I know, the maximum build difference allowed is 50 or 100, so a person using Archicad 26 build 5032 can work with a person using Archicad 26 build 5002.
Kind regards,
2023-05-16 03:17 PM
Builds within a x100 range are compatible.
So Builds 4000-4099 are compatible, Builds 4100-4199 are compatible, and so on.
