Teamwork & BIMcloud
BIMcloud Archicad Versions
Diora
Hi!
I just got an approval to use BIMcloud for our group project, i.e. Team licence. Unfortunately I use Archicad 25, while other members in the group have 26. Can we still work on the project, by using a library of Archicad 25, not 26?
I cannot update to a newer version, because my laptop is too old.
Thanks
4 REPLIES 4
That's too bad.   A quick search here will show that everyone must be on the same version of Archicad to share a project.  Your only option is for everyone else to use 25 for this group project.
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
filip
Yes, and all of you need to have the same version and build also, for example, v26.5002, version 26, build 5002
Kaique
Hi Diora,
It is not possible to work in teamwork using different versions. Also, as far as I know, the maximum build difference allowed is 50 or 100, so a person using Archicad 26 build 5032 can work with a person using Archicad 26 build 5002.
Kind regards,
Kaíque Baêta Cruz
https://community.graphisoft.com/t5/Installation-update/Updates-for-AC26-NOR-4022-and-INT-4019/m-p/3...
Builds within a x100 range are compatible.
So Builds 4000-4099 are compatible, Builds 4100-4199 are compatible, and so on.
