When my publishing method is set to print and I try to publish a layout, I get an error that I cannot connect to the BIMcloud server and it points to a wrong bimcloud address. How do I change what BIMcloud address it points to? I am able to sync and everything just fine to the correct BIMcloud server. This only happens when I use the print publishing method.
Thanks in advance.
Nathan
Operating system used: Windows 28.3110
