Custom Door Leafs from 20 disappear in 21 Teamwork
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2017-06-23 01:53 AM
Any fix? I'm looking at a 3d view with a ton of EMPTY OPENINGS..
I've tried even creating NEW LEAFS and they do not show up either...
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-06-23 01:54 AM
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-06-23 02:42 AM
If you open one of the door leaf objects from the embedded library, is the subtype set correctly?
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-06-23 02:43 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-06-23 06:31 AM
It's the LIST in the CUSTOM LEAF section of the door object contained over 50 door leaf options to choose from in 20... With AC 21, there are NONE...
The leafs are present in the EMBEDDED LIBRARY. And they do still have the CUSTOM LEAF subtype applied to them..
I recall this happening when moving a project from 19 to 20...
Odd thing is that when opening the .pln file in 21... they are all there... It's only after SHARING the file and logging in using teamwork that they disappear.
And it's not a Library Loading issue as they are all EMBEDDED.
Also note that I SAVED all embedded objects to FILE and loaded THAT library and still nothing shows in the dialog for door leafs.
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-06-23 06:26 PM
vfrontiers wrote:Sounds like this belongs in the Teamwork / BIM Server forum then. (I won't move unless you say so, Duane.)
Have you called GSNA support yet?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-06-23 07:05 PM
Karl wrote:I have emailed GSNA Support without any response yet...
Feel free to move over to TW issues...
We are currently porting the file back to 20 (which will have it's own issues, I'm sure)...
Any other things to try? We've never tried the MIGRATE feature of TEAMWORK... maybe that nets us something different?
BTW... Bozeman came up a couple time over the last month... Been thinking about you, Karl!
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-06-24 06:19 PM
Maybe worth trying the Migrate steps you mentioned before deciding to drop back to 20?
I've not messed with TW in a few years, so am otherwise useless for any advice.
Thought of you yesterday when one of the cats sleeping in the closet knocked the ACUWest polo shirts onto the floor. Seems like such a long time ago, but what a great time. Hope you're surviving the heat wave!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-28 03:23 PM
Implementation Specialist
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-28 04:18 PM
Visual Frontiers
