Teamwork & BIMcloud
How to rollback from 4020 back to 3006 BIM Server 18
I would like to rollback my BIM server 18 from 4020 back to 3006.
I tried searching online but I could not find anything.
If anyone could help with a link or something, it would be much appreciated.
Thank you
NCornia
Graphisoft Alumni
William13,
Run the BIM Server 18 installer on the BIM Server computer. There is a Repair function available. This will not affect your projects, only restore the BIM Server operational files back to the 3006 build.
May I ask why you are reverting? Is there an issue with build 4020?
PS - I will make sure that we post an article about this on Help Center.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Thanks for the reply,
The reason is that some clients of mine updated to 4020, and then found a problem and reverted back to 3006, except for the BIM server. they had a serious deadline and instead of fixing the problem they downgraded.
I got them to update to 4020 again and helped them fix the problem.
but I would like to know this for future error with hot fixes.
Thank you.
