How to set up Bim Server
Hello,
I have an issue with TW. I am a total newbie on that area. I would like to set up bim server on local machine, so my coworker could join the same project. I have same build on AC17 and BIm server, I have firewall exceptions turned on, same discovery ports on AC17 and BIM server...
what do I do wrong?
thanks!
princ
Eduardo Rolon
I have changed the title of the thread to reflect what is being asked.
Setting up TW is relatively easy if all users are within the same network and if they can see each other computers (for a network without a server) or that they can connect to a central server. It is more difficult to setup if the connection is remote (over the internet).
You have not indicated the operating system or what the basic problem is.
- Can your friend connect to the TW computer? i.e. open a folder in the computer hosting TW?
- is your friend using the same version of AC?
- is the connection remote or local?
- What type of network do you have?
- Does the TW server have a static address?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
