‎2009-09-17 08:20 AM
‎2009-09-20 07:28 PM
gkovacsp wrote:Thank you Gabor. This is great news. I look forward to the improvements.
I think (:)) this will improve in the future.
Gabor
‎2009-09-28 07:46 PM
‎2009-09-30 12:14 AM
Daniel wrote:There is the File\Libraries & Objects\Manager BIM Server Libraries Dialog where you can upload and otherwise manage Libraries on BIM Servers.
I am upgrading he office and have a question. Once BIM Server is up and running, with team members identified, but no projects created, do I use the BIM Library manager and upload a copy of the AC13 Library so there is a library to start with in the Server? WOuld I also want to load any other "office" libraries, texture libraries, etc.?
After uploading a library to the server, how is the updating of an office library managed? Do you need to re-upload the office library anytime a new part is created or modified?
Can you upload an alias to an office library so that it will be manageable in one location and pulled by the BIM server when necessary so that it is current for any project?I am not familiar with the Mac this much but I can imagine this is possible. Hopefully someone with a Mac and AC13 can answer this.
What about textures? We have some pretty large folders of textures that we pull from when needed. Would this be best left out of the BIM server and just loaded as embedded objects?Karl's above post may be applied to this situation as well.
Thanks in advance.
‎2009-10-08 08:23 PM
‎2009-10-08 11:13 PM
‎2009-10-09 06:18 PM
Wokka wrote:I've read all the posts and reading also http://www.archicadwiki.com/Teamwork/WorkFromHome
I don't like the way this is heading.....
I do a lot of remote work for my Architectural clients, usually just taking the whole file home, working on it and sending it back with Skype or FTP. I thought TW2 was going to be a great addon for me. I haven't done a lot of research on it yet so please forgive my ignorance..
Does this mean every time I want to log on to a particular file, I have to download the Archicad library (R12 with Cadimage 200MB), plus the actual file (up to 150 MB)? Is it a 'once off' download, and even after logging off, closing down, opening up again, do I need to download it all (the libraries) again?
I understand send/recieve is much much better and that's great.
Once again, excuse my ignorance, I'm trying to wrap my head around this stuff again with big deadlines looming......![]()
edit, buggerAfter all that typing, rwalllis just beat me too these questions..........
‎2009-10-09 07:15 PM
‎2009-10-10 12:56 AM
Why load any libraries/ .lcf's in to the server project at all ?the problem here is how to manage externally linked files to lib part itself such as macros and images. E.g. if you have shared macro by several lib parts how would you edit and synchronise it? Anyway the problem is really complex and I can assure you we went through this with GS several times.
Embed the parts as you go along.
Our issue here is that when one of my users joins a shared TW2 project for the first time, and endures the long load time, the library loading report still shows that many objects are missing -- even though I know they are in the server libraries that show as loaded.report it as a bug
Imagine if Apple had designed this thing.I quite admire your bold statement comparing GS to Apple but you need to be reasonable here.... BTW Apple is about to release second hotfix for SL and all of it within 2 months time after initial release so...
Would we all be having these painful, frustration-ridden conversations?you should read one of the Apple's forums about e.g. Mail4...
We have yet to successfully use TW2 to share a project. So to those who say this is "easy" my experience has been decidedly otherwise.ok, I give you this one. yes TW2 installation/maintenance has a pretty steep learning curve but considering the magnitude of this technology I do not think it is completely out of touch with a common user. Once you've set it up it is not so hard. And benefits are really tremendous.
‎2009-10-10 02:40 AM
‎2009-10-11 06:36 AM
