Teamwork & BIMcloud
Need to add a camera path in a TW file?
rob2218
is there a way I can do this?
Add a camera path to a TW file?
See attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
Link
My guess is that you'd need to reserve the path first. Try right clicking it in your Navigator/Organizer. It's down in the 3D area of your Project Map.
Link.
rob2218
thanks Link.
yeah..that's what it was.
Now...I'm having trouble with the output.
sometimes it'll create the proper MPG-4 file..sometimes it wont.
and I'm only able to see an animation that lasts 5 seconds total.
Settings in the "SET" dialogue box are a bit...umm...confusing.
Frames per second, Key frames, etc...need some help here as well.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Please re-post that separate question in the Presentation forum, as it is not a TeamWork issue. Thx. šŸ˜‰
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
