Problem with Teamwork views linked to PLN file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2010-02-23 04:01 PM
Today when i wanted to update the views of the Teamwork file, i get this error message: "Unsent changes in your source project are preventing the status checking process.
Go to the project and send your changes to the Server, then press the Check Status command again in the current project."
I did Send and Receive a lot of times, but to no avail, i cannot update my views. Even if i delete them and re-link them i get a blank drawing.
What can i do???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-23 11:04 PM
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-24 09:09 AM
From the Navigator i see the teamwork file listed as "Running" whereas the regular PLNs are listed as "Linked" whats the difference?
Even if i delete the missing views and re-link new ones from the Teamwork file i get blank drawings and the same error message. Seems something is stuck somewhere.
This is extremely annoying
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-24 04:58 PM
-forward merge merging in a blank AC13 template file
-if that doesn't work, save out a pln and then reshare. Test in the pla that you can fix the linking problem first before resharing.
Perhaps someone else here has another suggestion.
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-24 05:10 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-24 05:23 PM
The views are updating now miraculously... BUT... all the doors and windows and other objects are missing.
The BIM server libraries appear not to be loading on the PLN with the views, and there is no way of linking them... when i go to "Manage BIM server libraries" i get a blank window...
But why do i have to have the libraries loaded to the PLN with only the views?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-25 02:47 PM
BIM Server Libraries are usually not found for that reason.
And these hotlinkes also have a path which can get messed up in such a situation.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-25 02:52 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-25 02:57 PM
If it is identified by an IP address, then that should be used by all.
This is a bit of guessing by me because I have not encountered such situation myself.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-25 10:18 PM
http://archicadwiki.com/Bugs/Teamwork/LibraryNotFound
As to your original issue, I would think that the warning you get only notifies you about the status of the drawings being reliably displayed, but it should not prevent you from actually updating the drawings. So, after updating the drawings still should get them to the most current state, even though they are still marked as outdated after it. One possible way to fix it is that all the users who are signed in the source project send changes and "leave" the project. If everybody leaves the project, there should not really be any unsent changes. If there still are, then it' s a problem that only a re-share would fix. Save a PLN out of the project, and re-share it.
HTH,
Greg
VP, Customer Success, Graphisoft
