2021-06-09 12:44 AM
Solved! Go to Solution.
2021-06-09 01:39 AM
2021-06-09 01:39 AM
2021-06-09 07:38 AM
2021-06-09 10:11 AM
2021-06-09 06:42 PM
vuego wrote:Easy if you are running Windows OS
There is an easy solution with libraries/projects having different source directory. You map your Dropbox/Onedrive/Synology folder or even subfolder to a new unused drive letter. Doing this with the same on every computer solves library paths problems (the same applies to hotlinks, modules,...).
