2011-09-02 08:11 AM
9/2/11 8:08:23 AM com.graphisoft.TeamworkServerManager-v14.0[1151] Error: Failed to run TeamworkServerManager as service application 9/2/11 8:08:23 AM com.graphisoft.TeamworkServerManager-v14.0[1151] Exception: ServiceProcessException: Failed to start server manager: failed to check and set folder and file permission bits. 9/2/11 8:08:23 AM com.graphisoft.TeamworkServerManager-v14.0[1151] at /Volumes/Work/AutoBuild.Vitruvius/Vitruvius/Sources/TWServer/TeamworkServerManager/Source/Teamwork/Server/Manager/ServerManager.cpp(271) 9/2/11 8:08:23 AM com.graphisoft.TeamworkServerManager-v14.0[1151] Caused by: IOException: Failed to create folder: /Volumes/Data/TeamWork Projects/Attachments. (Error code: -2130640124) 9/2/11 8:08:23 AM com.graphisoft.TeamworkServerManager-v14.0[1151] at /Volumes/Work/AutoBuild.Vitruvius/Vitruvius/Sources/TWServer/TeamworkCommon/Teamwork/Common/IO/IOUtilities.cpp(218) 9/2/11 8:08:23 AM com.apple.launchd[1] (com.graphisoft.TeamworkServerManager-v14.0[1151]) Exited with exit code: 1 9/2/11 8:08:24 AM com.graphisoft.TeamworkMessagingServer-v14.0[1139] ACTIVEMQ_HOME: /Applications/Graphisoft/Mallipalvelin/Server Modules/1400/TeamworkMessagingServer 9/2/11 8:08:24 AM com.graphisoft.TeamworkMessagingServer-v14.0[1139] ACTIVEMQ_BASE: /Applications/Graphisoft/Mallipalvelin/Server Modules/1400/TeamworkMessagingServer 9/2/11 8:08:24 AM com.graphisoft.TeamworkMessagingServer-v14.0[1139] Loading message broker from: xbean:activemq.xml 9/2/11 8:09:37 AM com.graphisoft.TeamworkServerMonitor-v14.0[84] launchctl list returned unknown response 9/2/11 8:09:37 AM com.graphisoft.TeamworkServerMonitor-v14.0[84] launchctl list returned unknown responseSo. I am certain that this problem was because the ProjectFolder and AttachmentFolder was configured to RAID-volume.
2011-09-02 12:38 PM
