‎2013-05-29 06:59 PM
‎2015-02-19 09:55 PM
Mike_TNT wrote:
When trying to access a teamwork project that exists error message reads
"Cannot access the project because it is being used by another process"
‎2015-02-20 04:48 PM
gdlgurus wrote:I've seen this message when a .pln is aleady open on the same machine (would be too easy to say "you've already got the file open"), not sure how that can be happening when you are connecting to a teamwork file.
Hello! Following up on this thread and this other one (http://archicad-talk.graphisoft.com/viewtopic.php?t=35264 ), I have encountered the same problem. Curiously enough it only happens when trying to access our BIMserver from outside the office, using a remote connection. ArchiCAD starts well, gets a license from the keyserver located on the same computer as the BIMserver, connects to the BIMserver (it shows active projects), but when attempting to open any of the teamwork projects, the message appears:
‎2015-02-20 06:40 PM
‎2015-02-20 06:46 PM
‎2015-05-12 09:22 AM
‎2015-09-17 12:00 AM
