Teamwork & BIMcloud
Tips about Teamwork, plus BIMcloud functions and settings
Using multiple BIM servers.
Steve Jepson
Can you have 2 servers open at the same time?
I have a project I want to keep the server open but I would like sign in to another one.
If I sign into another server do I have to shut mine down?
If I do, does that mean no one can use my server while I am using another one?
If I pull my WIBU key out to use in on another computer, does that shut down the server so others can not sign in?
4 REPLIES 4
David Larrew
You should have no problems working on multiple BIM servers (as long as they are unique). When I demo'd AC13 last I opened 2 different files on separate BIM servers (one was my local server, the other was over the LAN).
Your key should not affect your BIM server. The hardware key is for your copy of ArchiCAD not the BIM Server or Manager (separate programs).
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
To add to David's answer to get your other question - nothing that you do as a client would ever be reason for shutting down the BIM Server. There are reasons to shut down a BS, but not related to any of your questions.
You can be joined to as many projects as you wish on as many servers as you wish. You do not need to leave a project in order to join another, or to switch between joined projects. Further, within each project, you can potentially access a separate server for each loaded library - speaking as an academic and not practical exercise.
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
vfrontiers
I see this thread was from a while ago... but the title is close enough for me...
I wonder if there could be some discussion on when it's appropriate to HOST separate BIM Servers?
Should I run 1 bim server and let the MODULES differentiate between 14 and 15?
Should I set up two completely different BimServers?
Is it possible / recommended to set up MULTIPLE BIM SERVERS on ONE MACHINE?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
schagemann
hi,
we have got a 'modular bim server' AC13&14 running on a mac mini which works rather well, at least for the AC14 projects. luckily the AC13 projects are legacy anyway and will be archived soon.
regarding your question though, here my 2 cents worth on determining factors for teamwork setup (btw. i was trying to get some other people to comment on a similar issue regarding hardware a while back, available here: http://archicad-talk.graphisoft.com/viewtopic.php?t=35906&highlight=😞
1. project / file size & number of users > basically & simplistically put one of the limiting factors on any server is read/write speed, i.e. a 7200RPM harddrive can only do so much;
2. hardware cost > what gives you the best bang for your buck;
also check out the following posts:
on archicad user management: http://goo.gl/Eyozv
article on archicadwiki on best AC15 TW practices: http://goo.gl/zliik
at the moment in mac environment, i reckon the following setup is the best:
mac mini server, 2.66 GHz, 8GB RAM, 2x500GB
reformat & install with normal OSX, then install bim server and the projects on the two separate drives for optimal access speed.
but really i would wait until the next gen macs come out and include thunderbolt - also note that the mac pro series is rumoured to be upgraded soon...
any other thoughts are much appreciated.
ds.
VKTRS | macinteract
Design Technology Managers - all on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
