Teamwork & BIMcloud
Warning message in tutorial, I need help!
Hi Guys,
Just starting out in the Tutorial & setting up the Teamwork section. Bim is installed up to Step 2, Sharing a Project, opened the "Col-02.pm" ArchiCad Project file, then opened, File\New\ShareMenu item. When I select the Bim server from the list (only one there) I get a Warning message, "Client not compatible with selected server" Server version 14.0.3004, Client version 14.2.4204.
From my request, you can probably tell I'm not very computer literate, so please treat me like a dummy & take my hand & lead me through as simply as you can!
The BIM Server is an earlier version (called "build") than ArchiCAD.
BIM Server is the server when doing Teamwork projects, ArchiCAD is the client.
You should run the latest hotfix and update both ArchiCAD and the BIM Server.
It might be that ArchiCAD is actually on the latest build so you will not be able to update that. Run the update and see if you ca nstill update the BIM Server to the same build.
If this is not possible, you may have to uninstall both, then reinstall both, then apply the latest hotfix to both.
Thanks for the reply. I kept looking about last night, for a fix for my problem & tripped over it in a previous posting. I'm sure this has been dealt with many times in the past. Was just before midnight when I came across it & then did the Hotfix on the Bim server, problem solved.
Again thanks for your response, please don't go to far away I'm sure I will have many more for you to try & deal with in the future!
I'll leave this posting up, for any other Newbs that encounter a similar problem.
