2009-09-28 11:10 PM
GRAPHISOFT BIM Server is a standalone application that ships with AC13 for free. This application is the core of ArchiCAD Next-Gen Teamwork solution and can be installed as a separate application from the ArchiCAD 13 installer. This application synchronizes the changes in the new Teamwork solution between client computers and the central model on the server.Link
Requirements for BIM ServerLink
[.....]Note for Windows users: QuickTime 7 or later and Java 6 or later are required to run ArchiCAD. ArchiCAD installer will automatically install Java 6 (build 1.6.12) and QuickTime 7 if they are not present on your computer. [.....]
2009-09-29 01:01 AM
2009-09-29 11:39 PM
Erika wrote:I think you do not necessarily have to install it on every computer that has ArchiCAD on it.
The BIMserver Manager is installed on all computers that want to access the BS. You will install it on all computers in your office that will also have archicad installed.
2009-10-01 08:02 AM
2009-10-01 03:31 PM
2009-10-01 11:23 PM
2009-10-02 09:50 PM
2009-10-02 11:20 PM
2009-10-03 12:14 AM
another Moderator
2009-10-03 01:17 AM
laszlonagy wrote:The one they are shipping you mean. You can get them with memory.
I asked the guys at GS.
The Codemeter dongle does NOT have memory in it so it is not also a pen drive.
My bad.
