We value your input!
Teamwork & BIMcloud
Windows Firewall (what do I let though?)
Gus
Attached is an image of my firewall settings.
I have been having several problems with ArchiCAD and I keep wondering if it is because my firewall is blocking things. Things like some Send/Receive occasionally, and now I don't get messages from teamwork teammates. I'm wondering if I should be letting everything related to archicad 19 get through the firewall. Should I check all the ArchiCAD 19 things in this firewall dialog and let them through or are there some things we don't want to let ArchiCAD do?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
Something is wrong with the image, it does not appear.
Can you repost it?
Gus
Hopefully this image works better.
If not I will try to change it to a .jpg.
Madison WI
I checked my Windows Firewall settings and saw that I, too, have multiple ARCHICAD 19 entries.
Your program lists each Private/Public permission in a separate row so two rows can belong to the same application. Mine, which is the default Windows Control Panel, lists both in the same row.
You can check the details for each row. When I did I found many of the items were for AC19 beta versions, which remained in the system.
If you have the same situation, you can delete all those items belonging to beta versions.
