Eduardo Rolon
28.1.0 Preview: 3D Window Glitch
With any "3D Style" that has "Shadows" on"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
6 Replies 6
runxel
Rather looks like you have two walls in the same position:
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Eduardo Rolon
Nope. Single wall.
If you don't have shadows on there is no glitch.
AC29 US/INT -> AC08
Eduardo Rolon
Update,
Looks like moving the Sun in the 3D Window setting resets the shadow and the glitch is removed.
The original file still keeps the glitch.
AC29 US/INT -> AC08
runxel
Huh, interesting. So it happens only in the "shadowed" side?
Mh, I've seen similar issues with wonky graphics drivers, but you're on Mac, so that shouldn't be the problem either. Maybe send the file to the support for them to check it? 😕
Eduardo Rolon
Not necessarily on the shadowed side.
File sent just in case.
AC29 US/INT -> AC08
Batu Gezer
Hi Everyone,
Thanks for bringing this to our attention. we have done some background investigation, and the reason why this is happening is that the sun is parallel to these problematic walls. This is the reason why, as mentioned, moving the sun fixes the problem, as it is not directly parallel to it. :
Another solution would be to try switching to the physically based renderer, which uses shadow mapping instead of shadow volumes in this case it doesn't intersect with the shadow.
Hope this helps!
Kind regards,
Batu
Batu Gezer
Technical Support Engineer | Graphisoft SE
