Visualization
3D PDF
Hi everyone,
I'm trying to build up my first 3D pdf for client presentation.
I did an easy test exporting the 3d model of a simple wall as .u3d file, and then I placed it in my empty pdf page.
Then I tried to import the .u3d file of a building in design, but Acrobat crashed a few times. The size of the .u3d model I'm trying to import is 60-70 Mb.
Does anyone use 3D pdf on a regular basis? Is my file size too large?
Thanks!
Enrico
32 REPLIES 32
Dwight
3D PDF is kidstuff.
You might show a cell phone model, but not a building fully detailed.
Give up.
You would be better off to embed a VR object.
Dwight Atkinson
...which is not to say that you can't have a very large and detailed 3D model in your .pdf. You can put the entire builing in the .pdf as a 3D object no problem. In the .pdf it will spin arround just as fast as you can in ArchiCAD. You can explor the entire builing, make new 3d views, do all sorts of things like add voice notes, movies, more stuff than you ever even want to do. Pass the file around to everyone on the team and let them explore it add comments. You must check it out. Acrobat is so much more than a way to view your prints.
I use the Adobe Acrobat 9.3 Pro Extended and have just tested it with the new IFC fire formats we can generate with ArchiCAD 14. It works great.
Save the file as .ifc , then open it with the Acrobat. From there you will be superized at what you can do with it in the Acrobat. You can add dimensions in 3D, sections, lighting, a dozen or so viewing options, solid, wire frame, transpaent, etc..... layers, notes, camera views, it's amazing. All with the Acrobat in 3D. Very good stuff.
Also, the Acrobat will handle STP and other 3d file formats as well.
I am still testing to see how many differecnt ifc. formats the Acrobat will open. The ifczip files reduce the size of the model very well.
By null at 2010-07-02
Gerald Hoffman
Steve, I would say I would have to agree with Dwight on this one. I am not sure if your post of a one story house with roof is your example of a large model. You may be correct in being able to use it on fairly small residential or commercial projects but I tried doing some 7 story condo buildings which I was involved with at the time and they brought my computer to it's knees.
I tried this in Acrobat 8 Extended so Adobe may have improved things in the upgrade. I ended up exporting to SketchUp which was a free download for the client and very user friendly. Even then I usually had to break the building down into parts to make it usable.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
For me, importing a 3ds file (saved from AC) into Acrobat gave the best performance. Importing u3d files seemed too slow in terms of performance.
Adrian Tudoreanu
I just posted that as a quick example of a typical 2 story 4,200 sqft house that is probably modeled much more than most, to show that you can have more than just a small model in the Acrobat and you can view it with no loss of speed at all.
Nemetschek is now launching new 3D pdf features in Italy. I have an 85 Mb sample on my desktop.
It may be kids stuff, but clients are like kids and they like to play with toys like a 3d pdf.
I also think that this could really help clients (who are not usually field experts and cannot read drawings) to better understand the deisng.
Is Graphisoft going to implement anything like that any time soon, or the plan is to stay behind like we are used to?
http://www.nemetschek.it/links/progettodigitale/download
This is no kid's toy. This is next generation of architecture presentation.
I really hope Graphisoft is doing something about it. I'm getting sick of being always behind.
Thanks for posting the link to this .pdf sample.
This is exactly what I have been doing for a long time with Acrobat 9 Pro Extended. I am testing now to see if version 10 is an improvement or not.
My demo runs out today.
People keep telling me no, it's too slow, or sure for a small project...
Download the example in the link Enrico posted and you will see that it is not slow and it is very easy to make a pdf document like this.
This is not a new Acrobat feature at all.
Also, this is has nothing to do with the CAD program. You can do this now if you have the Acrobat Pro, and more. They could have added some audio too for verbal descriptions, instructions, etc...the digital content you can add to your documents is limited only by your own imagination.
To give it a try, download the pdf and use it as a template for making your own presentation. Just edit the links to use your own stuff.
You can do all of this with ArchiCAD and the Arcobat.
Dwight
Trying Adobe's turbine 3D download moves smoothly enough now. I take it all back from a year ago.
Dwight Atkinson
