Chris_Lz
3D view - no materials shown
Hi everyone, please help with an issue.
Everything I model shows grey as in the attached image, regardless of what materials I assign to the elements.
There are no graphic overrides, I have selected detailed shading to be shown and hardware acceleration is selected.
I never encountered this problem in all the years I'm using Archicad, so I don't know where the problem is.
Thank you.
1 Solution
DGSketcher
Legend
Check your 3D STYLES  settings. Someone may have overridden a setting in the "Detailed Shading".
The other option is Renovation Settings. For example you may have Graphic overrides in the renovation settings active that are modifying existing elements to grey.
Go to post
DGSketcher
Legend
