2016-08-10
09:24 AM
2023-05-11
11:40 AM
Noemi Balogh
2016-08-10 01:26 PM
2016-08-10 01:36 PM
2016-08-10 06:27 PM
David wrote:
Jonathan:
Are the lights recessed into the ceiling? If so, you will need to create holes in the ceilings for the lights.
2016-08-11 12:43 AM
2016-08-11 12:44 AM
2016-08-13 03:17 PM
Jonathan wrote:Since your image has the green arrow, I am guessing that this is the PhotoRender Preview, not an actual photorender. The Previews are not perfect, so try an actual photorender to see the result. You can also post a screen shot of the Lamp Settings > Light Settings for the Lamps that are not working, as well as the name of the Scene you are using, and someone may spot the issue.
Here is another image
