Dwight
AC 9 Water rendering tip for LightWorks
Decrease water transparency from 32 - 72 for improved reflection
Dwight Atkinson
7 Replies 7
Dwight,
I'm convinced.
This water stuff is cool.
I look forward to having some time to play with it. When I did a bunch of renderings in Art*lantis for presentations the only materials we changed were glass and water and they made all the difference.
I also learned that too much reflection can look pretty strange. Even if it is real, it is not always what one thinks looks real.
Dwight
And nothing is ever as smooth or perfect as in cyberspace so grime and roughness make folks comfy. It is more like their living room.
Dwight Atkinson
Ben Odonnell
Really nice Dwight.
Is that a reflection map that you have used on the water?
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Dwight
That is a modified [increased opacity] LightWorks material as applied to the waterwave object - a poly mesh of adjustable amplitude - reflecting the actual background elements of the scene.
So, unlike the old days, we didn't need to cheat.
LightWorks allows for control of five aspects of material quality, including a sort of fuzzy blob opacity that is ideal for mapping a water surface.
Dwight Atkinson
Ben Odonnell
Thanks for that.
I'm off to try it
Cheers.
Ben
Ben O'Donnell
Dwight
here
Dwight Atkinson
Dwight
blobby reflection
Dwight Atkinson
