Visualization
AC11, don't see Artl export in 3D window, Add-on Manager
AC 11 1086 on a Mactel, I have an ArtlantisR-Studio_out.bundle file version 3.0(109) installed by default that I understand should be doing the thing, but I don't get the Save As option in the 3D window and I don't see the add-on in Add-On Manager.
12 REPLIES 12
There seems to be some correlation with some weird icon behavior.
The working add-ons have the normal 2D puzzle piece icon. With the Artlantis bundle file I am getting a 3D Lego piece icon, and this happens even when I copy the file from some other computer in which they are seeing the normal icon and the add-on works .
Yesterday I had the same problem with the C4D export add-on, which somehow got fixed in one of the many attempts, and I now realise it was showing the Lego icon before and is showing the 2D puzzle icon now.
owen
Ignacio i know you are not on Leopard but maybe the problem has the same cause as my issues with the C4D add-on ... behaviour sounds exactly the same. Ralph posted a very helpful fix:
Mac OS X 10.5 Leopard and AC11?
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Hi Ignacio,
See this thread in which Thomas Holm had the same problem a bit over a week ago:
http://archicad-talk.graphisoft.com/viewtopic.php?p=104025&highlight=#104025
He has not posted if he found a solution.
Regards,
One of the forum moderators
Thanks Owen and Karl. Following hints from those threads I ended up solving the problem. I posted the solution that worked for me at
http://archicad-talk.graphisoft.com/viewtopic.php?t=19439
Glad you figured it out, and thanks for sharing the solution, Ignacio. (What a strange thing...)
Thomas Holm
He has not posted if he found a solution.l
I did not. I've had too much work lately, I resorted to AC10 in that project instead. I'll try Ignacio's solution tomorrow if I have time.
owen
ok well that is bizarre..
cheers,
Owen Sharp
Thomas Holm
I've made it work now thanks to all tippers. My solution was a bit different from Ignacio's although the problem seemed similar, see
http://archicad-talk.graphisoft.com/viewtopic.php?p=104969#104969
I used Ralph's tip from this thread http://archicad-talk.graphisoft.com/viewtopic.php?p=104348#104348
with a twist.
Rename the add-on ArtlantisR-Studio_Out.bundle into ArtlantisR-Studio_Out.apx
Regard,
Pierre
Abvent s.a
