‎2018-02-12
08:47 PM
‎2023-05-11
11:55 AM
Noemi Balogh
Solved! Go to Solution.
‎2018-02-14 12:28 AM
Lori wrote:Aha. Now I understand what you're after. (This "Presentation" forum is still the right place for this topic - I had moved it here.)
What I would like to do is use the 3D Document for the building lines and the white model effect from CineRender for the shadow. This would all be generated from the model within Archicad 19, no outside photo will be used. I can use the same camera position, but it is tedious to get the scale to match up. I am wondering if there is a more accurate/easy way to get the scales to match so I can overlay them on my layout sheet.
‎2018-02-13 07:18 PM
‎2018-02-13 08:52 PM
