Archicad 21 CineRender Issue Warning! CineRender...
I can't seem to render using CineRender. Message in the photo says:
Warning! CineRender by Maxon add-on has unexpectedly quit. Archicad should be restarted.
any suggestions on how to fix this?
macOS High Sierra
8gb RAM
3 Replies 3
I have the same problem... i search solutions everywhere, but i found no solution.
I hope someone can help us...
Erwin Edel
Contact your reseller for support, this is not a tech support forum, rather an user forum.
While some people might know what to do, I think in your case it is unlikely, the last time I saw someone mention these errors, someone from Graphisoft requested them to contact them about system specs and supply error logs and such.
8 GB of RAM is very low for any kind of rendering though, but Out Of Memory errors ussually just results in a black render.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hi guys,
This may be the solution to your problem:
https://helpcenter.graphisoft.com/?p=75744
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
