Aaron Bourgoin
Animation Question: Animated CAT scan through a building
I'm interested in creating an animation similar to the one Graphisoft has used for years on their website.
Is there a way to create an animation that shows a cutting plane passing through a building in the 3D window. This would be like a series of CATscan images of the building as the cutplane moves from one end to the other.
Any suggestions appreciated.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.1.0 USA
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
3 Replies 3
There was some discussion about this a few years back, it might be worth checking out:
http://archicad-talk.graphisoft.com/viewtopic.php?p=105943
Aaron Bourgoin
Thanks for the pointer. I tried a search for this but really wasn't sure of what terms to use. Merci mille fois!
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
Aaron, another possibility is stitching single rendered images into a .gif in photoshop, kind of like this discussion only through sections instead of building up.
http://archicad-talk.graphisoft.com/viewtopic.php?p=132578&highlight=#132578
