Visualization
Animation Question: Animated CAT scan through a building
Aaron Bourgoin
I'm interested in creating an animation similar to the one Graphisoft has used for years on their website.
Is there a way to create an animation that shows a cutting plane passing through a building in the 3D window. This would be like a series of CATscan images of the building as the cutplane moves from one end to the other.
Any suggestions appreciated.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
There was some discussion about this a few years back, it might be worth checking out:
http://archicad-talk.graphisoft.com/viewtopic.php?p=105943
Aaron Bourgoin
Thanks for the pointer. I tried a search for this but really wasn't sure of what terms to use. Merci mille fois!
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.1
Aaron, another possibility is stitching single rendered images into a .gif in photoshop, kind of like this discussion only through sections instead of building up.
http://archicad-talk.graphisoft.com/viewtopic.php?p=132578&highlight=#132578
