2025-01-09 09:39 PM
ArchiCad 28 - AI visualizer doesn't generate anything it just generates the same thing i have in the window to start with ?
Operating system used: Windows 11 pro
Solved! Go to Solution.
2025-01-16 11:22 AM
WOOO HOOOO many thanks Oleksandra!!!! - that was all it was .. (all - being the key to a 1.5week search!) the Upscale image tick box - dear lord what a palaver!
Many thanks I am most grateful!!
2025-01-09 10:49 PM
Hy @ad5968,
If you have a subscription license this could be a technical issue, if so please contact your local reseller. But if you don't have a subscription license, then it will not work by default since it is only exclusive to users with a subscription license.
Stefan
2025-01-09 11:11 PM
Hello and thank you - i have an educator 1 year license - i don't know if that counts as a subscription?
I think it is supposed to work for students and i want to teach it to them
2025-01-09 11:14 PM
If that is the case, definitely contact a local representative from your region to help you out :), or maybe wait a little bit and see if someone from the forum gives you the needed solution. 🙂
Cheers
2025-01-09 11:16 PM
thank you!
2025-01-13 02:08 PM
Perhaps so others don't have to waste so much time or know different , although forums say its available to students (the AI visualizer) it looks like maybe only in 27 which I couldn't get to work. In 28 it doesn't work either , and after much research and time it appears it is not available to students or educators a their licenses are not cloud licenses.. might just be a UK issue too , maybe its different in US etc.
2025-01-13 02:17 PM
For me, it's about a waste of time. The company should have focused on developing other fundamental features that could better help improve architectural practice for example.
2025-01-13 02:21 PM
If it was a license issue, you would get a warning that the license is not suitable.
It is definitely available to students.
2025-01-13 02:40 PM
Hello Barry - i spent a long time looking thorough posts .
I couldn't make it work in 27 after a considerable amount of try's and research. i then tried with 28 will also no avail. (but I'm no expert and i may still have missed something)
Finally the below reply from Graphisoft indicates that it wont work in 28.
2025-01-14 02:04 AM
OK, so we have conflicting information.
That link I posted says ...
@Norbert Kucsma , can you shed any light on this?
