Seems to be a known bug, when I checked in with the Dutch reseller.
Some things I've noticed (might be random still):
- rendering from the 3D window seems to be better than rendering from a previousrender as the active window
- turn on render safe frame
- with two point perspective, toggle the two point perspective button one or two times to 'reset' the proper view
- when you change settings in sketch render engine, the next render will 'bug' out the camera, so abort it, go in 3D window, 'reset' the camera position + two point perspective and render again
- save the cameras to a path for easy resetting back to what you want it to be like
I haven't tried axonemetric renders yet in 22, no tips for that.
www.leloup.nlArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
