Can one apply different material half way a wall?
I would love to do know how to do that if it's obtainable.
2 Replies 2
You can do this with a profiled wall. Simple walls would have to be stacked.
Edit: Another trick would be to make a material with a texture set to the colors and pattern you want.
Dwight
Matthew refers to the Complex Profile function where a fill defines a wall shape, allowing separate material surfaces.
See: 'complex profile" in Archicad Help - refer to "Edge/Side Materials for Profile Element"
Dwight Atkinson
