I recently started using ArchiCAD 13, and when I try to create a VR Object in 13, it tells me "To create VR documents, place the VR Engine into the Add-Ons folder." I create these with ArchiCAD 12 quite often and it works fine.
I found the QuickTime VR Engine in the Visualizations folder in the Add-Ons folder for AC12 and copied it into the AC13 folder, but it still didn't work.
Has anyone else had this problem? If so, how do I make it work in AC13?
