‎2019-05-17
07:06 PM
‎2023-05-11
12:53 PM
Noemi Balogh
Solved! Go to Solution.
‎2019-05-18 12:02 AM
‎2019-05-20 08:54 AM
LaszloNagy wrote:That was perfect, thank you very much
I checked it and that vertical gray band is part of the Texture's image file.
So you would have to extract the LCF containing the Surface Catalog, and modify the image file in an image editing software to remove that band.
I have actually created it out of interest. The modified Texture file is the attached ZIP file.
Place it in the Embedded Library of the Project and then modify the Surface to assign this Texture instead of the default one.
