2006-08-31
06:23 AM
2023-05-11
12:31 PM
Noemi Balogh
2006-09-01 12:27 PM
2006-09-01 12:46 PM
but I got fed up with the clumsy export from Archicad......
2006-09-01 06:10 PM
Rafal wrote:AFAIK the official exchange plugin has not been updated for AC10 and I am still waiting desperately for it. I use it a lot and it is very efficient since it updtaes changes to the model in AC wihout having to reassign materials.
There is a direct export from AC to C4D when you want to render Archicad scene (another plugin is for modeling purposes) but... in german.
Any practical experience with it?
2006-09-01 08:02 PM
2006-09-21 09:17 AM
ejrolon wrote:Who is responsible for this plugin - Maxon or Graphisoft? I would have thought the latter - afterall this is just another document output format such as 3DS or DWG, all of which GS must write the translator for?
2006-09-21 10:01 AM
2006-09-21 12:07 PM
2006-09-22 12:42 AM
2006-09-22 01:51 AM
Rafal wrote:Yes Maxonform plugin is GS outsourcing of a solution to Archicads modeling deficiencies. It switches to C4D with the AC modeled ghosted where you can model new or remodel existing elements using C4D's more complex modeling tools and it then brings everything modeled back into Archicad as a single .gsm object. No parametrics and good luck editing the object script to give it any - it is the object equivalent of a mesh. Anyway ...Who is responsible for this plugin - Maxon or Graphisoft?
There are two plugins for AC<->C4D communication.
I am not quite sure but it seems that plugin for rendering in C4D is made by Maxon.
Connection between Archicad and MaxonForm for modeling purposes and saving it as gsm file is made by GS.
Am I right?
